Haledex Suggestions
Old May 20, 2007 | 07:04 AM
Tusa's Avatar
New Member
Default Haledex Suggestions
Apparently my Haledex is fried. Dealer quoting close to 4K to get it replaced. Any suggestions as to where to get it for less? Refurbished?....any suggestions are welcomed.
Thanks
Old May 20, 2007 | 07:22 AM
MOBlueTT's Avatar
Member
Did they tell you "what" was fried? or Why? IF it was just a controller, that's a cheap fix!
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default My suggestion would be to confirm the diagnosis first.....>>
It may be something as simple as a bad controller (relatively common) as opposed to a completely malfunctioning Haldex (rare). Find someone with a VAG-Com and run the electrical diagnostics and see what (if any) codes you get. Used controllers can be had here relatively cheaply...Unfortunately the entire Haldex mechanical unit is sold as a subassembly that includes the differential and is, indeed, expensive..
Something as simple as a bad brake light switch (really common and a $10 fix) will completely disable the haldex.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1452481.phtml">Run these checks yourself to confirm....</a></li></ul>
Old May 20, 2007 | 07:24 AM
MOBlueTT's Avatar
Member
Morning Steve
Old May 20, 2007 | 07:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Hi Gil!
Old May 20, 2007 | 07:29 AM
MOBlueTT's Avatar
Member
A question... so what are you driving to TT East this year? ;-P
Old May 20, 2007 | 07:33 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Time will tell....:-)
Old May 20, 2007 | 07:37 AM
MOBlueTT's Avatar
Member
lol well I have Defcon 1 &amp; 42 DP, just wanted you to be able drive a "Firm &amp; Fast" ride ;-P
 Pouria Savadkouei
 Michael S. Palmer
Old May 20, 2007 | 08:26 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Oh, Trust me....it will be Firm and Fast!
Old May 20, 2007 | 08:28 AM
Tusa's Avatar
New Member
Default Re: Did they tell you "what" was fried? or Why? IF it was just a controller, that's a cheap fix!
I've spoke to the Mechanic, he basically said, based on what you are telling me, its most likely the Haledex unit...I guess I need to get somebody trustworthy where they don't just want to "sell" me a new Haledex, instead of a less expensive controller.
It does make a noise, similar to a CV Joint gone bad when you turn. On a minimun turning circle, wheels tend to lock themselves almost....car will still move, but it takes a bit more power to get it going.
