vag boost measurements..help please....TIA
I noticed lately there doens't seem to be as much kick when I stomp on the gas. I recorded measureing blocks for 115 but I don't know how to read the data. According to the conversion charts from mbar-psi, I'm pushing 32lbs of boost. That can't be right. At about 6k RPM VAG is recording 2250mbar. The other weird thing is as soon as I get off the gas it drops to 1050. I would think the turbo would stay spooled up. The engine load at 6k RPM is saying the engine load it 178%.
I know I'm losing some boost from using the VW MAF but does this data sem right?
Turbo is spooled with out throttle opening, it's just not building pressure (Bled off by the diverter valve). A Boost machine will get you more boost, more of the time with lighter throttle openings..<ul><li><a href="http://www.modshack.info/bm.htm">http://www.modshack.info/bm.htm</a</li></ul>
Run the folllowing logs on one screen
002
118
204
3rd gear, 2000-redline at WOT. Email me the log and I'll look at it..
