timing belt won't go on!
Old May 21, 2007 | 11:56 AM
boobiestt's Avatar
New Member
Default timing belt won't go on!
Any tips getting this thing on? Should it even be this tight? please any ideas are welcome. I'm about ready to release the upper bolt from the tensioner and try sswinging it back in after getting the belt over the crank pully.
TIA
Old May 21, 2007 | 12:19 PM
4o66's Avatar
New Member
Default Mine was a PITA >
Took me and my brother to get it on. I put it on just a little on each gear and when it was on all, pushed it the rest of the way on, and that did the trick for us.
Old May 21, 2007 | 12:28 PM
nikhil's Avatar
Default it's supposed to be very tight...
i wouldn't release the tensioner until you're sure the belt is on properly.
when we were trying to get it on, we found that the belt would skip a tooth before catching on the sprocket when we started to rotate everything
so the trick/technique that we used when putting mine on was to align the bottom of the belt (by the crank sprocket) so that it was one tooth past the mark where it should eventually be. then, when you start to rotate everything to get the belt on, the belt will "skip" to the correct spot and you can keep rotating to get the whole belt on.
let me know if that does/does not make sense. good luck.
Old May 21, 2007 | 02:09 PM
MOBlueTT's Avatar
Member
Default This is the PITA part, 2 of us spent 30 min ...
Pushing the belt on while 'rolling' the crank / cam via the main crank bolt... You'll nener have any leverage to put the tensioner or roller on after it's over the cam.. 2 people, big pain... It Will Go On - hang in there!
Old May 21, 2007 | 05:02 PM
AmarilloA4's Avatar
New Member
Default Re: timing belt won't go on!
I wrote up the second timing belt job that I did a few months back.
The trick to getting the belt on is the order you feed the belt on.
I clamp the belt to the top sprocket.
feed the belt down to the bottom sprocket and insert something to hold it on the correct mark.
The last is the water pump sprocket which you can work on by hand (if the tensioner is retracted)
See pics in link.
Hope this helps....<ul><li><a href="https://forums.audiworld.com/tt/msgs/1624120.phtml">Timing belt write-up</a></li></ul>
Gilbertorodz
10
May 25, 2023 08:04 AM
wrenchin27tt
2.7T V6 Discussion
Apr 19, 2008 12:50 PM
TTROAD
Jun 24, 2007 08:14 PM
jeanfor
Audi allroad
Jan 4, 2005 06:49 PM
CMS4
13
Mar 16, 2003 07:25 PM
