Symptom: Sounds like loose change when going over bumps...
Old May 21, 2007 | 12:05 PM
Tummy's Avatar
New Member
Default Symptom: Sounds like loose change when going over bumps...
When going over bumps, with the top down, I can almost always hear what sounds like loose change clinking about from the suspension. Of course the dealer never hears it.
What could it be?
Old May 21, 2007 | 12:25 PM
MaD MaTTer's Avatar
Make sure the top bolt is torqued to the correct spec. otherwise it will start to rattle
Old May 21, 2007 | 12:40 PM
olddawg's Avatar
New Member
Default Yea, I had that (or similar)...
Went to the dealer 4 times for the same sound. Went around the dealers neighborhood looking for potholes or bumps that would cause the car make that sound because they could never hear it when I left the car with them. Finally found a school's driveway that I could reproduce the sound consistently so I took the tech for a ride and he stood in the rain as I went up and down the driveway. I was told it had something to do with the brakes and the only notation on the service record was "brake modification - N/C". Now I'm getting the same sound on the passenger's side, not happy. Did a few searches for "jingling" and saw that it happens mostly on A4's and one post said there was a TSB for the A4's on it but I could not find it. Something having to do with a retainer clip and the caliper.
Old May 21, 2007 | 01:46 PM
Tummy's Avatar
New Member
Sounds like the same problem. "jingling" was the keywood I needed to search!
Old May 21, 2007 | 03:50 PM
aviattor.3's Avatar
Default hey Mad MaTTer, OT but..great sig!
Your car looks almost chromelike in that pic.. did you photoshop the pic?
Old May 22, 2007 | 03:05 AM
Bobcz's Avatar
Default Re: Symptom: Sounds like loose change when going over bumps...
Had the same problem with my 2003 roadster. Finally found a road where I could reproduce it and took the tech for a ride. He concluded it was control arm bushings. Hasn't recurred since.
Old May 22, 2007 | 05:48 AM
MaD MaTTer's Avatar
Thnaks.. i had a pic i took it as the sun was setting and played with the colors in photoshop.
the_runner213
Audi A3 / S3 / RS 3 MKII
10
Jun 28, 2024 02:51 AM
Carabnr
Aug 29, 2019 03:40 PM
rdluchs
13
Nov 22, 2005 04:23 PM
FinnTT
Aug 3, 2003 12:31 PM
Stoyak
May 21, 2001 03:49 PM
