Running hot AND cold?
VAG-COM shows nothing.
Is the thermostat dying? Any other thoughts?
Many thanks.
There have been a lot of Fan and Fan control problems here recently.
Monitor the temps with the HVAC controls and see what the actual temps are:
Press [Recirc] and [Up arrow] buttons together. Use left 'temp' control
Dial to 49. Press [Recirc] button again to display value. On average, normal operating temp is around 90 (degress C)
To return to HVAC controls back to normal, press [Recirc] and [Up arrow]
buttons together.
Display should return back to temperature control/display.
60k miles is the recommended interval to change out the timing belt (along with all other related components). Check to see if you have coolant pumping back into the reservoir at idle and while revving the engine. If no coolant is being pumped back in, you have a busted water pump. If you aren't overheating, then keep a close eye on the temp until 60k miles.
...also, use Vag Com to see if you simply don't have an engine coolant temp sensor going out- a common issue.
~john
~john
