Strange clicking sound since DEFCON 2 and Stoptech stgII install..
Old May 25, 2007 | 09:21 AM
Lowcountry's Avatar
Default Strange clicking sound since DEFCON 2 and Stoptech stgII install..
the sound is coming from the left rear wheel area. It sounds like there is a pebble inside the wheel that keeps skipping around. It also sounds like a loose valve train sounds. Tickety tickety tick tickety tick... you get the idea.
Upon visual inspection, I can find nothing loose, nor any pebbles in there. The sound is very subtle, but it is driving me nuts. Anyone have any idea as to what the culprit might be?
Thanks!
Old May 25, 2007 | 09:26 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Chip: I have the exact setup w/o issues. Have you ....
put it up in the air and spun the rims to see if they are rubbing the lines or something else?
YGM on another subject BTW.
Old May 25, 2007 | 09:31 AM
Lowcountry's Avatar
Default Negative, Mr. D. I'll try that this weekend, but visual inspection doesn't
point to this.
Checking mail now, thanks!
Old May 25, 2007 | 09:32 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Look for a nail in the tire when you do this!
A tick tick tick with the speed of rotation is the symptom..
Old May 25, 2007 | 09:34 AM
Lowcountry's Avatar
Default Already did that. It isn't ticking at steady intervals like a nail would.
There seems to be no pattern at all, actually.
Old May 25, 2007 | 09:48 AM
Sully's Avatar
Member
Default Do you have spacers? What tire size and wheel size
I had the same thing a few years ago when I had 8.5" wheels with wider tires. It ended up being I was rubbing on the strut housing.
Old May 25, 2007 | 10:29 AM
GorTT's Avatar
Is this the rear of left front wheel? Otherwise what does defcon/stoptech have to do w/?
Old May 25, 2007 | 10:49 AM
polishadonis's Avatar
Check the brake line if it is hitting anything.
 Pouria Savadkouei
 Michael S. Palmer
Old May 25, 2007 | 10:51 AM
TTinCT's Avatar
Rest In Peace
this only occurs while moving....correct?
Old May 25, 2007 | 11:16 AM
Lowcountry's Avatar
That's right, Hans. It seems to stop when brakes are applied, too.
