POLL: Those running the Greddy RS DV - what springs and what adjustment are you using.....
I get a little flutter when I lift at high power.
It's installed with a Forge relocation kit, oriented the same as your picture.
I checked the diaphram a couple of days ago, it's in "as new" condition... perfect shape...
I bought it new, and it's logged 40,650 miles on my car.
"right now" torque after upshifts.... my favorite Greddy RS characteristic!
Forge 006
Hyperboost HX
GFB Stealth FX BOV
Greddy RS
so far, i've had no problems with the Hyperboost HX, so i have it back in. since i'm pushing 26psi, i'm probably at the point where diaphrams are useless.
with the Greddy...before i took it out last week...i was getting fluttering AND honking on a regular basis. i had it set up several different ways. originally, outer spring with 4-1/2 turns. worked fine for 7K miles. then i started getting honking. i tried 2 springs and a 'light' tension. almost constant honking in some instances...light fluttering.
it hasn't been consistent, and since i didn't have the time or the patience to fuss with it...i yanked it out. put the Hyperboost HX back in after i cleaned and lubed it. working very nicely...for now.
