Help! Unable to free OEM rotor from hub. Sprayed rotor-hub interface with penetrant.
Old May 26, 2007 | 03:34 PM
sTTevo's Avatar
Default Help! Unable to free OEM rotor from hub. Sprayed rotor-hub interface with penetrant.
<center><img src="http://pictureposter.audiworld.com/77447/oem_rotor.jpg"></center><p>Have banged on rear with hammer/wood block. Have tried rocking it and pulling it.
Yes, the retaining screw was removed. That was easy.
The StopTech install is on hold until I can get this off.
That black thing in background is ST-40 caliper. Picked this up locally from another TT guy last Fall.
Anyone have any tricks???
Old May 26, 2007 | 03:56 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Spray again, Let sit, Whack HARDER!
Old May 26, 2007 | 04:05 PM
Damwatsyoname's Avatar
hit it from the back and rotate it..the rust is just caked on the hub
Old May 26, 2007 | 04:19 PM
Jdog35's Avatar
Junior Member
"Sptay"? Is that some new type of pate?
Old May 26, 2007 | 04:21 PM
TTinCT's Avatar
Rest In Peace
Default that is called>>>>
a Coors Light lisp! ;-P
Old May 26, 2007 | 04:30 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
More like keyboarding from the easy chair.....:-)
Old May 26, 2007 | 04:46 PM
TTinCT's Avatar
Rest In Peace
:-D
Old May 26, 2007 | 05:01 PM
stilljester's Avatar
Member
Get a bigger hammer and don't be shy. Hit-&gt; Rotate -&gt;Hit -&gt; Rotate.....PB Blaster Helps
 Pouria Savadkouei
 Michael S. Palmer
Old May 26, 2007 | 06:07 PM
sTTevo's Avatar
Default OK fellas, the old rotor is off and the StopTech BBK is on........
<center><img src="http://pictureposter.audiworld.com/77447/stoptech_r.jpg"></center><p>Thanks for your advice and moral support.
And remember, if at first you don't succeed........
<img src="http://pictureposter.audiworld.com/77447/biggerhammer.jpg">
try using a bigger hammer.
Old May 26, 2007 | 07:13 PM
JustAdam's Avatar
Very nice Steve!
