Dumb question about a chip
Chip upgrades should run about $500. One of the best values per $ spent for your TT.
Most of the vendors that do chips, APR, OCT, GIAC, REVO, can do the upgrade through your OBD port under the dash.
Hope this helps.
Several good chip manufacturers (in no particular order)
- APR
- GIAC
- MTM
- REVO
other owners will 'chip in' I'm sure.
If you Google these names, you'll find their websites and the names of their vendors. In the latter TT, you can flash the OEM chip with new program(s) using stock, 93, 98, 100, and even higher octanes. You can get valet (safe) mode, and most programs are 'invisible' to the dealer. One caution: most chips clear the rev limiter.
A typical 180TTQC with MTM chip, VTDA, and Borla is making well over 200 BHP, and a good bit more torque than OEM specs. A 225 TT can easily make 240 HP on just a chip. Other accessories can add to the HP, but the adds are not linear.
HTH-
