Quesetion about engine fans
Old May 27, 2007 | 07:48 AM
element2050's Avatar
New Member
Default Quesetion about engine fans
I only see the lower passenger fan spinning. I don't recall every seeing the driver side fan on. What is this fan for and when does it come on?
Thanks guys!
Old May 27, 2007 | 07:54 AM
InTTruder's Avatar
AudiWorld Awesome User
Turn on your AC and open the hood. It should come on.
Old May 27, 2007 | 07:59 AM
GorTT's Avatar
Default It'll come on when you're idling, somewhere around 100C >
unless it's broken, or you have a sensor problem, or a few other reasons. Check the temps on the AC readout and go have a look around 98 - 102C.
Old May 27, 2007 | 08:00 AM
New Member
Default I just got the car about 75% hot>>
Pulled in my drive way only the passenger fan is going. Turned on AC still only one fan is going. I'm guessing something is broke. Any Ideas?
Broke in the past month list: Whats next?
Bad Boost Leak
Drive Side Window
Engine Fan
Old May 27, 2007 | 08:02 AM
InTTruder's Avatar
Default FCR: fan control relay
While you're at it, make sure you have a current GREEN temp sensor, and that you are not losing water from the "crack pipe" (coolant manifild on left side of block).
Old May 27, 2007 | 08:15 AM
New Member
Default Got it up to 103C just sitting in my drive way
The fan never came on
Old May 27, 2007 | 08:16 AM
New Member
Green temp sensor. I don't see anything dripping.
Old May 27, 2007 | 08:17 AM
GorTT's Avatar
keep it going a bit, I might be wrong on the kick-in temp.
 Pouria Savadkouei
 Michael S. Palmer
Old May 27, 2007 | 08:19 AM
New Member
Default Side note I pulled a fault code for the O2 Sensor.
How do I know which one is bad?
Oxygen (lambda) sensor B1 S1 Internal resistance too high p11113 - 35-10 Intermittent
Old May 27, 2007 | 08:24 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
I thought it was around 104 but I might be wrong..
