Is hydraulic pneumatic sealant necessary for brass oil fittings?
Old May 27, 2007 | 05:30 PM
ShafTT  (aka CrafTT)'s Avatar
Member
Old May 27, 2007 | 06:00 PM
XCLR8TT's Avatar
Senior Member
Are they compression fittings? If so, probably all you will need is a little teflon tape.
Old May 27, 2007 | 06:37 PM
coasTTal's Avatar
Default Depends on exactly what you are up to.......
When I did my relocated oil cooler I initially used the white teflon tape on screwed joints. I found that the oil slowly ate away at it and got a leak. I replaced with the yellow tape used for natural gas lines and it has worked well.
Sci-fi_Wasabi
34
Nov 12, 2018 12:14 PM
jakie1962
Sep 24, 2009 12:16 PM
signal11
Nov 24, 2007 06:58 PM
SFourEA
Mar 18, 2002 11:59 AM
