Thoughts on Front Camber kits?
Old May 28, 2007 | 11:46 AM
imager993's Avatar
Default Thoughts on Front Camber kits?
I was at the track yesterday - the same track as whodkne and MCPAudiTT actually - and was running my brand new Nitto NT-01 track tires. They wore a TON on the outside edges and I realized that I need more front negative camber than my stock setup can give me. Right now, maxed out, I can get only -0.9 degree of camber and I need at least -1.5 or even -2 for these track tires to start wearing evenly across the whole tire.
Coilovers to drop the car will be coming but not for a little while, so for now I am looking for an option for my stock suspension to get me more negative camber in the front without dropping a ton of money. A few options I have found...
<a href="http://www.k-mac.com.au/">K-MAC Camber/Caster Plate</a>
<a href="http://www.ingallseng.com/">Ingalls Engineering</a> <a href="http://www.ingallseng.com/Instructions/35655.pdf">Part #35655</a>
This <a href="http://www.drivewire.com/performanceparts/Eibach/audittquattroalignmentkit.html">Eibach Kit</a> I found
Or the <a href="http://www.ground-control-store.com/products/description.php?II=653"> Ground Control Camber/Caster Plates</a> that <a href="https://forums.audiworld.com/tt/msgs/1203124.phtml">everybody</a> <a href="https://forums.audiworld.com/tt/msgs/1441003.phtml">here</a> <a href="https://forums.audiworld.com/tt/msgs/1623820.phtml">has</a>
Has anybody used the K-MAC plates yet or is the Ground Control the best way to go?
Thanks!
Old May 28, 2007 | 12:25 PM
GorTT's Avatar
Interesting; I run -1.5 w/o any kits.
Old May 28, 2007 | 12:31 PM
imager993's Avatar
but I am running at the stock height.
Old May 28, 2007 | 12:35 PM
GorTT's Avatar
understand; airc, stock max 'recommended' is -1.27.
Old May 28, 2007 | 12:38 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You realize I assume...>>>
any camber change results in toe change as well and needs to be compensated for,for best results. For a real trackside quic (?) set-up you'll need a Smart Camber toos as well as a set of Toe plates..
Old May 28, 2007 | 12:39 PM
imager993's Avatar
Default The best the alignment shop could get was -1.0(R) and -0.9(L)
I am looking for something around -2 for the track.
Old May 28, 2007 | 12:42 PM
imager993's Avatar
Default :) I was already looking at those.
I get the camber tool, but how hard is the toe to measure and modify?
I am thinking about doing a different alignment for the track and the street. If anything it will give me practice for future racing setups I will do on future dedicated race cars.
Old May 28, 2007 | 12:43 PM
imager993's Avatar
And I read somewhere that you sell the ground control kits?
 Pouria Savadkouei
 Michael S. Palmer
Old May 28, 2007 | 12:51 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ummm...No. You need to contact this guy....>>
In the header of my Fotki album..<ul><li><a href="http://public.fotki.com/ttschwing/ground_control_camb/">http://public.fotki.com/ttschwing/ground_control_camb/</a</li></ul>
Old May 28, 2007 | 12:53 PM
imager993's Avatar
Thanks Steve!
