I have to be bad---- after reading here how long MODS take I took
Old May 28, 2007 | 04:46 PM
Badd TT Bone's Avatar
Default I have to be bad---- after reading here how long MODS take I took
the plunge. First stuff easy-- So lets go for suspension-- Read how tos on shock and spring upgrade said should take 3 hrs. Started at noon and I'm still at it. How do you line up the flat spot bolt on the K Macs ( trial & error 2 hrs) now I cann"t get it hooked on rotor side oh well in the morning will try again. At least I got V3's on one side
Old May 28, 2007 | 05:03 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I discovered a neat trick for the Kmacs....>
Yeah, it is tough to get it lined up on the outboard end. Last time I did this I took a few ratchet straps and ran them around the Trailing arms.....A few cranks to pull the loose one in and the bolt lined right up....Easy!
Old May 28, 2007 | 05:43 PM
IT WORKED THX Steve, should go in FAQ
Old May 28, 2007 | 06:33 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Great!
Daniel Grant
Dec 8, 2008 09:21 AM
S4Dean
12
Mar 21, 2008 07:52 AM
nobodeuno
Sep 5, 2006 05:29 PM
CK:1.8T+Rabbitâ„¢
Mar 19, 2005 06:32 PM
A4ORCE1
Jan 18, 2004 01:49 PM
