Arrgh - flutter under boost; is this my Greddy? >
Car was idling after running at highway speeds for a bit then was sitting in traffic on the interstate (pouring ran as well)...pulled away and she stumbled hard...got a flashing CEL....went away moments later.
Conclusion...more than likely something got on the MAF wire (or it was failing) or the condensation built up on the inside of the ****...Never happened again....
VAG it if you can...you should see an error Will...
