Blocks 032 and 002 logs >
Old Jun 4, 2007 | 07:24 PM
GorTT's Avatar
Default Blocks 032 and 002 logs >
032: Idle value 0.6%, part throttle value, 0.0%
002: Engine RPM: 720/min, Engine Load: 15.0% Ave. Inj. Period: 2.04 ms, Air Mass Flow: 2.19 g/s
From my understanding, lean maybe; but...?<ul><li><a href="https://forums.audiworld.com/tt/threads/440872.phtml#1649859">link to my flutter post below</a></li></ul>
Old Jun 5, 2007 | 02:53 AM
TTinCT's Avatar
Rest In Peace
Default nope>>>>
block 32 is fine...she is a tiny bit lean at idle, but nothing to worry about...she is getting plenty of gas...
on block 2...you need to record some values in a 3rd gear pull..idle does not tell ya much..
Any errors?
Old Jun 5, 2007 | 04:22 AM
GorTT's Avatar
Default what should I be looking for on a 3rd gear pull? I logged 002 rev range in neutral >
fwiw, but I'll try for one on the way in to work today; 3rd gear, 2k to redline? I did have some misfires btw; almost wondering if it plugs - 20k on them.
Old Jun 5, 2007 | 04:46 AM
RoberTT-WWCD's Avatar
g/sec should be around 150+ Anything lower, and the MAF is suspect.
Old Jun 5, 2007 | 04:50 AM
TTinCT's Avatar
Rest In Peace
Default what Robert said below>>>
and the pull is best from 2k to redline if possible....there has to be load on the motor to get accurate readings on block 002.
I got 24k out of my Denso's so you might be ok there...Gaps could be off a bit with that kinda mileage so you may want to pull one and check it just to be safe.
Old Jun 5, 2007 | 04:53 AM
jhoeppel's Avatar
2nd gear pull might be safer (depending on where you're driving) and give same results, no?
Old Jun 5, 2007 | 04:57 AM
Default Yeah, I check mine every 5K when I clean the DV and TTDA. I set my IK22s...>>
to 0.030. I found if they get to 0.038 or higher, I start to get mis fires at high RPMs.
Just a thought.
Old Jun 5, 2007 | 05:01 AM
TTinCT's Avatar
Rest In Peace
Default 3rd gives a higher boost request>>>
and gives the best results. 2nd would be just that, my second choice if space and speed are issues....
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 5, 2007 | 05:08 AM
GorTT's Avatar
ok - thanks! I'm off; maybe get a chance to check; otherwise noon :-(
Old Jun 5, 2007 | 05:17 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Highly unlikely that 032 value is good...>
the chances of a 0.0% correction on the partial is slim to none. You using shareware or a pro-diag?
