Is it really neccessary to change out everything that is offered...>>>
Old Jun 5, 2007 | 07:28 PM
Room4TU's Avatar
Default Is it really neccessary to change out everything that is offered...>>>
in the Dieselgeek TB Kit? Most shops that I talked to will only change out the TB, water pump, and serpentine.
Old Jun 5, 2007 | 07:52 PM
Scenic Driver's Avatar
Yes or you'll be sorry when the tensioner fails
Old Jun 5, 2007 | 09:12 PM
TTinWV's Avatar
Default See administerturbo's recent notes
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1650076.phtml">Clicky</a></li></ul>
Old Jun 6, 2007 | 04:35 AM
jhoeppel's Avatar
Default Related: since the tensioner is the weak point, how difficult is it to simply change that?
probably a silly question, but administerturbo's post got me to wondering???
Old Jun 6, 2007 | 04:53 AM
OldSchool AG's Avatar
Senior Member
Default no easier than changing everything
plus there's no proof that the tensioner is responsible for all of the failures.
Old Jun 6, 2007 | 05:41 AM
Black BeauTTy's Avatar
Exactly. Seems to me the water pump impeller is more problematic.
Old Jun 6, 2007 | 05:43 AM
adminisTerTurbo's Avatar
Default but the crap impeller won't break the belt
or cause it to loose tension
Old Jun 6, 2007 | 06:57 AM
joe@vwvortex's Avatar
Default I disagree - tensioner was a known weakspot on early 1.8T and failed
regularly causing TB to snap. The belts themselves rarely fail.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 6, 2007 | 07:56 AM
maaliish's Avatar
water pump is as much to blame as the tensioner. Change it all or beware.
Old Jun 6, 2007 | 07:57 AM
maaliish's Avatar
Default Sure it will. It can jam, freezing up the water pump and that will break the belt.
Which is what I mostly heard of happening on the TT.
