OSIR Carbon Fiber Door Handle install tips??
Old Jun 6, 2007 | 08:32 AM
bullitz400's Avatar
New Member
Default OSIR Carbon Fiber Door Handle install tips??
Hey guys. My buddy and I have the whole door handle / window switches apart and are having a hard time installing them with the carbon fiber piece installed. Was wondering if anybody had any install tips on how to get these to fit? We have the service manual and instructions from TTstuff but they are hard to understand. Any tips would be appreciated. Thanks
Old Jun 6, 2007 | 08:38 AM
tylor's Avatar
Member
Default Where are you stuck?
Can't get them into the door panel, can't get them into the switch area, can't get the panel back in place, can't realign the bolt?
Old Jun 6, 2007 | 09:05 AM
bullitz400's Avatar
New Member
Default Re: OSIR Carbon Fiber Door Handle install tips??
Trying to get the window switch to line up in the silver piece so that the window will open and close. Thanks a lot!!
Old Jun 6, 2007 | 09:13 AM
tylor's Avatar
Member
Default Did you remove the individual switches before removing the switch housing?
You may have damaged it...<ul><li><a href="https://forums.audiworld.com/tt/msgs/1224024.phtml">Check out this thread</a></li></ul>
Old Jun 6, 2007 | 09:15 AM
bullitz400's Avatar
New Member
Default Re: Where are you stuck?
OR , I can get the window switch aligned but then I can't get the carbon fiber piece in.
Old Jun 6, 2007 | 09:25 AM
bullitz400's Avatar
New Member
Default Re: Did you remove the individual switches before removing the switch housing?
Pretty sure I didn't break any pieces. Everything fits fine into place but I can't align the window switch if the handle is in. If the handle is not in the switch aligns perfect but I can't get the carbon fiber piece in. Thanks again.
Old Jun 6, 2007 | 09:37 AM
bullitz400's Avatar
New Member
YEAH!! read the DIY install and took the switch itself out of the assembly, put everything together with the handle installed, popped the switch through the bottom, SHABAM PERFECT!! Thanks again Tyler!! Can't wait to get my intercooler in the mail now!! Side mounts and everything is off waiting for this beast to go on! Thanks again!!
bjc2974
Q7 MKII Discussion
Mar 7, 2017 11:00 AM
blooscloos
Audi Original "S" Cars
Oct 8, 2007 04:36 PM
AUDIDOIT
Mar 14, 2007 05:21 PM
richmart109
Jul 16, 2005 10:40 PM
