question about air mass readings
In two 2nd gear full-throttle runs, the Air mass peaked between 125g/s (1500~5500 rpm) and 138g/s (2000~5680 rpm)... and on a 3rd gear run when entering the highway, it peaked at 131g/s (at 5880 rpm).
For a non-chipped 180, I'm thinking they should peak about 145g/s. Do these airflow readings look Ok?
TIA, ~john
On the Pressure drop, that's usually a leak. Pressure test the system..
On a side note, over the past several weeks, I have noticed when starting her up in the morning that the engine catches with more oomph than normal, revving for a brief moment higher than it did before, as if I'd slightly tapped the accel pedal when turning the key (I don't touch the pedal). This is very brief and the idle settles back to normal within a second or two. I'm starting to wonder if this is related to the O2 bank 1 sporadic system too rich code (which was additive trim, so that would suggest at idle, right?)
