Drop in Boost on 3k RPM Runs in 3rd
We would start at 3k RPM in 3rd gear, honk the horn 3 times, and compare how we would pull on each other to redline. For the most part, we were completely nose-to-nose, however I noticed on my boost gauge that I would spike to 21-22psi @ 3k, hold at 20psi from 3k to 4.5k, then from 4.5k to redline it would steadily drop to 10psi. Is this normal? I'm asking this because my friend's TT would continue to slightly pull after we've reached 4.5-5k RPM, while I would start to taper off.
Secondly, what sorts of mods would help me retain boost longer? FMIC? 3" downpipe? Silicone hoses? Larger intake manifold? Adjust my Modshack Boost Machine? What's recommended..
I've realized his car is possibly 300lbs to 400lbs lighter than my car, especially with my heavier rims. While this has a lot to do with acceleration, I doubt it plays a part in the ability to hold boost to the higher RPMs.
Thanks!
Generally at 4500 + heat soak sets in....ECU dials down boost as a protective measure. Best thing you can do for WOT High boost performance is an FMIC..
The Samco turbo intake hose was made because the Audi hose would collapse around 5K. The IC hoses are the same ID throughout the hose whereas the Audi tapers.
The DP will help with the upper RPMS by being less restrictive and 1/2 inch ID larger.
As far as the intake goes, Maybe getting it extrune honed will help with flow. But Audi has done a good job on this peice.
Just my $0.02
Oh --Schwing. I finally installed the boost machine. Cool. Had to MAKE myself dial it back to about 21-22 peak. Was seeing 24 !
Makes a small but noticable difference. I mounted it by clamping to the strut brace. just enough room to clear the hood. (For other readers I used the stock air box. Call me old and conservative.
