SOS,i changed the theremostat,but still too hot,is there cause it? the water
Old Jun 6, 2007 | 09:14 PM
TT911's Avatar
New Member
Default SOS,i changed the theremostat,but still too hot,is there cause it? the water
seems doesnt go through the top water holse,and seems there is no water circulation...damn, what should i do......please help!!!
Old Jun 6, 2007 | 10:17 PM
JustJeff's Avatar
did you 'burp' it? modern cooling systems trap air, you have an air bubble.
Old Jun 6, 2007 | 11:20 PM
Russ Scott's Avatar
could be a broken impeller in your water pump...
Old Jun 7, 2007 | 12:15 AM
TT911's Avatar
New Member
should i open the cap on the bottom of radiator,let the air go out first?
Old Jun 7, 2007 | 12:21 AM
TT911's Avatar
New Member
Default damn..the water pump looks ok, no leaking,no noise.the water went to inside when i refill
the first time,but when i refill the second time,it wont go inside anymore, i open the tank, there is alot of air coming out, wondering, is there a cap on radiator that i can refill the coolant?
Old Jun 7, 2007 | 03:56 AM
Rocky-in-Connecticut's Avatar
Default your water pump is toast...
...if you see no coolant being pumped back into the resevoir, then your water pump impeller is busted. Probably got big plastic chunks lying right inside the block.
Old Jun 7, 2007 | 06:51 AM
Russ Scott's Avatar
Default "wondering, is there a cap on radiator that i can refill the coolant?"
no, only the coolant recovery tank has a cap...
see Rocky's comments /\ /\
the OEM pump has a plastic impeller, known to shatter/break. When it does, reduced or no coolant circulation is the result. You have to remove the pump to inspect it. If it is bad, replace it with a new metal impeller pump only, OK...
Old Jun 7, 2007 | 08:59 AM
graviTT's Avatar
Junior Member
WOW,whats your current mileage?
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 7, 2007 | 12:20 PM
TT911's Avatar
New Member
where is the pump impeller located it? where i can get a metal one?thanks
Old Jun 7, 2007 | 12:50 PM
Russ Scott's Avatar
Default Re: where is the pump impeller located it? where i can get a metal one?thanks
<center><img src="http://pictureposter.audiworld.com/34314/water_pump.jpg"></center><p>
The impeller is part of the water pump
many suppliers carry the improved metal pump:
ECS Tuning, others... try a search for this
Here's a pic, from a link posted by blackfnTTruck /\/\<ul><li><a href="http://www.amp82.co.uk/tt/timingbelt/">the link</a></li></ul>
F18Lumpy
12
Oct 27, 2017 05:17 AM
EMUBritish
Audi 100 / A6 (C4 Platform)
Dec 30, 2007 12:07 PM
quattro20v
Audi Original "S" Cars
Oct 29, 2007 10:10 AM
Corey
Jan 1, 2006 10:17 PM
Michael Benno
Jun 14, 2004 01:36 PM
