Throttle Body Reset - is this true?
Old Jun 7, 2007 | 09:16 AM
esanmiguel's Avatar
Default Throttle Body Reset - is this true?
I saw this in the UK TT forum:
how to do a "Throttle Body Reset"?
OK, before answering how to... this (apparently) is why... "if your car is driven for a long time without thrashing then it will limit the max throttle to 75% I believe. Reseting just gives you 100% again" And this is how..
The Engine needs to be cold, so don't do this after a long drive or nothing will happen.
Turn the ignition on without actually starting the engine and wait for about 3 minutes.
Turn off the ignition and it's all done.
Is this true?
Old Jun 7, 2007 | 09:17 AM
graviTT's Avatar
Junior Member
I was under the impression that you needed a VAG-COM to reset the TB
Old Jun 7, 2007 | 09:20 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default That's how to do it...the rest (75% statement) is BS....>>
The electronics are constantly adjusting to your driving style, conditions and sensor input.
You should reset the ECU fuel maps every once in awhile too...Disconnect the battery for that.
Old Jun 7, 2007 | 09:37 AM
esanmiguel's Avatar
Default So if I disconnect my battery
It should reset my TB and ECU maps right? For how long do I disconnect?
Old Jun 7, 2007 | 09:39 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup...2 minutes or so..>
Just flip the key to on and do not start or touch the pedal for a minute or so while the TB sets itself..
Old Jun 7, 2007 | 09:40 AM
roadyTT's Avatar
And don't forget to have your radio codes handy
Old Jun 7, 2007 | 07:12 PM
sTTevo's Avatar
Default Steve - How does this work when you have 3 program APR chip? Does the reset only affect
maps for the selected mode? Does it rest all 3 programs?
Old Jun 7, 2007 | 07:16 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Just re-sets the programming maps...>>>
That alter Boost, fuel and timing. Basic adaptation values remain in the eprom but will adjust up or down slightly to compensate. Mostly the MAF and 02 sensors affect the adaptation maps..
 Pouria Savadkouei
 Michael S. Palmer
ODARROC
1.8T Discussion
Jan 14, 2008 01:03 PM
CowboysRock
Feb 14, 2005 07:09 AM
RageRacer
Aug 9, 2003 06:03 PM
alfabutt
Jul 30, 2003 06:32 PM
HappySedan, now with K04 power :)
Aug 27, 2001 02:58 PM
