normal amount of filings on rear diff drain plug?
Old Jun 8, 2007 | 09:25 AM
Rocky-in-Connecticut's Avatar
Default normal amount of filings on rear diff drain plug?
doing a complete fluid exchange on my 2001 TT 225, 60k miles. (also spark plugs, timing belt and all associated components)
I emptied my rear diff and the drain plug magnet had some metal filings on it, not a whole lot, but surprising to say the least. Also, what Redline fluid is recommended to refill the rear diff?
I changeed out the Haldex filter, drained, and refilled the unit with one tube of new Haldex fluid. But some fluid escaped while trying to put the plug back in the bottom, so I checked the refill level and it hasn't reached the plug. I'm not sure how far below the proper level is in there now, but how much of a concern is it not to be filled enough?
Old Jun 8, 2007 | 10:21 AM
SparTTan's Avatar
Default Regarding the Haldex, a little spillage is normal.
The tube of Haldex oil is 275 ml, and the fluid capacity of the Haldex clutch is 250 ml. So it is designed to spill a little. I think you should be OK if you didn't spill like half the tube.
Old Jun 8, 2007 | 10:29 AM
Scenic Driver's Avatar
Default To quote XCLR8TT >>>
"There is enough in the tube to fill the Haldex and completely cover your arm."
Gary Knox
Dec 6, 2014 03:57 PM
MarTT
Sep 21, 2008 12:05 PM
CO2.8
Jun 28, 2006 11:05 AM
Zwoobah
Audi Original "S" Cars
15
Apr 3, 2006 03:48 PM
gimp2.7
11
Nov 11, 2004 07:30 AM
