Are these codes leaning to bad MAF
Mass Air Flow Circuit -G70: High Input [Sporadic]
16795 P0411 163
Secondary Air Injection System: Incorrect FLow Detected [Sporadic]
18010 P1602 163
Power Supply (B+) Terminal 30: low Voltage [Sporadic]
17963 P1555 163
Charge Pressure: value above maximum charge pressure [Sporadic]
After that, make sure all your vacuum lines are ok, esp. the one going to the combi valve.
Next we need Vag Com measuring blocks 32 and 2. post results.
They are all sporadic so they may not have all happened during the same ignition cycle and didn't happen on the last ignition cycle.
I also run an n75h valve so some of this didn't surprise me.
