Strange ABS noise at low speeds.
Old Jun 19, 2007 | 10:30 AM
Mike55123's Avatar
New Member
Default Strange ABS noise at low speeds.
I actually have 2 problems. At any speed less then around 15 mph, when I stop ABS engages. Yes it's ABS, yes it's modulates the pedal, and I can hear it. Any idea what might actually be wrong? What part, or what would be causing the abs to engage? Seems as if it's engaging on only one wheel, I think the drivers front. It also makes a noise when taking off in first, or reverse at about under 10 mph, while not even braking. Any ideas?
My next question I pretty well already know the answer to. I have a random miss any time I hit full boost. I'm guessing I need to check the plugs, wires, and coils, and go from there?
It's a 01 TT with 68k on it.
Old Jun 19, 2007 | 05:34 PM
J. Patterson's Avatar
Default FWIW I had a longitudinal accel sensor cause abs pulsing and pedal feedback.
Dealer changed longitudinal sensor, lateral sensor brakelight switch, and $1000 from mine to his. Now all is good. Do you have lights or codes? I had ESP lit. ABS lit sometimes, and codes. (01273 if I remember correctly)
Best of luck to you. I still flinch when I press the brakes :-)
Old Jun 20, 2007 | 07:46 AM
Mike55123's Avatar
New Member
Default Re: FWIW I had a longitudinal accel sensor cause abs pulsing and pedal feedback.
I had a abs light once, but only once, and it went away, didn't store a code that I could tell. It's only from speeds 0-5 mph, nothing more. And it's REALLY starting to **** me off. Hoping I don't need to buy a 1000 dollar sensor.
theloosa6
34
May 2, 2012 12:28 PM
vw_steve
Aug 25, 2010 02:10 AM
GIAudi
Apr 23, 2010 11:48 AM
Jax
Jun 20, 2006 08:17 AM
wookiee
May 14, 2002 06:05 PM
