O2 sensor replacement
Old Jun 20, 2007 | 07:23 AM
duanejakob's Avatar
New Member
Default O2 sensor replacement
Does someone have a good description on how to replace the O2 sensor on a TT? I am not much of a mechanic but am out of work right now.
Old Jun 20, 2007 | 07:34 AM
JustJeff's Avatar
Default My advice: Pay Bubba at a muffler shop to do it. Might require a torch to loosen it, plus it needs a
special tool. to remove it.
Old Jun 20, 2007 | 07:38 AM
JustJeff's Avatar
Default A typical Bubba at a muffler shop. (your version may vary, but not by much.)
<img src="http://www.loomknitting.com/auditt/images/fmexhaust2.jpg">
Old Jun 20, 2007 | 04:26 PM
CartoonDog's Avatar
Default easy, one wrench job.
You can pick up the universal replacement from BOSH (sp?) at any autoparts. While your there pick up a O2 socket. It is a deep well (22mm I think) with a slot cut out for the wire. My TT has two o2 senders, I dont know about all models. Simply remove the one and replace it with the one you bought. The kit comes with the wiring splice or you can resolder the OEM connctor. Its a $50-80 job. GL
Old Jun 20, 2007 | 06:03 PM
JustJeff's Avatar
last time I tried that on the A4, i nearly broke my arm-had to get a torch on the sender
adminisTerTurbo
Audi Original "S" Cars
18
Apr 8, 2008 11:07 AM
Eric 2.7
Dec 14, 2004 04:23 PM
shaneS4
Mar 3, 2003 08:35 AM
