With coilovers, will raising front 1/4 inch mess up the alignment specs? I was told TOE will be off
Old Jun 20, 2007 | 07:39 PM
marksk1's Avatar
Old Jun 20, 2007 | 07:55 PM
XCLR8TT's Avatar
Senior Member
A little bit, but why raise the front?? The whole point with coilovers is to let you lower it???
Old Jun 20, 2007 | 08:14 PM
marksk1's Avatar
Default The reason inside >>>
The rear is alllll the way down as far as it will go, and there is still a 1/2in wheel gap.
The front is farr down and has almost NO gap. The car has that RAKED appearance and not sure if im feelin' it on the TT..
I dont really want to lower it, but it kinda looks awkward, when I took pics earlier I didnt take any straight side shots but... idk
<img src="http://i3.photobucket.com/albums/y79/eurotek/TT-Spacers-03.jpg">
I might leave it, idk
Old Jun 21, 2007 | 02:44 AM
LonelyTT's Avatar
We've got the same problem tho
Old Jun 21, 2007 | 03:49 AM
OldSchool AG's Avatar
Senior Member
actually, that's not the whole point of coilovers
Old Jun 21, 2007 | 06:48 AM
joe@vwvortex's Avatar
Default Did you remove the white "spacer" plate from the spring mount on the rear trailing arm?
only leave the top black plastic on the rubber, remove any spacer. That will help drop the back IF you want. Other than that ANY changes to ride height will affect alignment.
Old Jun 21, 2007 | 07:34 AM
marksk1's Avatar
Yes i did remove that peice. But I also have the older KW springs in rear
Old Jun 21, 2007 | 11:35 AM
TwisTTer's Avatar
Default do you have v2's or v3's? if you have the latter it can go much lower than what you have it set at
any change minor or major will affect alignment
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 21, 2007 | 12:03 PM
marksk1's Avatar
I have the former... v2s... Dont wanna mess up the alignment so ill prolly keep it
Old Jun 21, 2007 | 01:35 PM
TwisTTer's Avatar
Default did you flip the perches? if you do it will look like what I had when v2's were on my car...
<IMG SRC="http://img.photobucket.com/albums/v685/twistter/rear2-1.jpg">
