Wierd brake problem.
Old Jun 21, 2007 | 07:56 AM
Mike55123's Avatar
New Member
Default Wierd brake problem.
My ABS engages anywhere between 0-5 mph, always. In reverse, forwards, neutral, engine off key forward. If I'm going between 0-5 abs engages, makes some weird noises and modulates my braking. Any suggestions on this? No ABS light on. Pads are almost new, can't seem to find any obvious problems.
Old Jun 21, 2007 | 08:07 AM
maaliish's Avatar
Default Vag the car and make sure its ABS. Does it drive perfectly at higher speeds?
Could be ABS sensor (cheap) or ABS module (expensive) if it is at all related to ABS. Does it do it on all 4 wheels or only one?
Old Jun 21, 2007 | 08:25 AM
InTTruder's Avatar
AudiWorld Awesome User
Sensor come loose maybe?
Old Jun 21, 2007 | 08:52 AM
Mike55123's Avatar
New Member
Default Re: Vag the car and make sure its ABS. Does it drive perfectly at higher speeds?
It's hard to tell since it's at such slow speeds. ABS works at higher speeds normally. It feels like the drives front maybe back, I can't isolate it. It drives just like it should at anything above 5 mph. Just doesn't make alot of sense
Old Jun 21, 2007 | 12:52 PM
maaliish's Avatar
I'm pretty sure that in VAG you can see ABS engage so give that a try.
DxC
17
Sep 4, 2006 10:24 AM
teddylove
Nov 2, 2005 08:54 AM
audiDTM
Aug 13, 2005 09:10 AM
+pressure
Dec 10, 2004 09:46 AM
