Front hub wheel bolt question.
Old Jun 21, 2007 | 08:50 AM
Silvr_Surfr's Avatar
Member
Default Front hub wheel bolt question.
I have a 5mm spacer on the rear that I want to move up front. The bolts I have for these are a little longer than the prefered 33mm long bolts (28+5). But they fit into the rear hub without hitting anything.
Does anyone know how much longer of a bolt I can put in the front without hitting anything? I would hate to have the bolts fit then have them take out a sensor or something when the wheel spins. I only have a jack so I can't spin the wheel by hand for a test.
Thanks for any help, Chris.
Old Jun 21, 2007 | 09:17 AM
joe@vwvortex's Avatar
You should be ok up front as well - +/- 2mm isn't a problem
Astronut
Apr 24, 2006 11:08 AM
fignewton
Nov 20, 2004 03:04 AM
Tomasz@Startup
Mar 30, 2004 05:18 AM
Julian_B
Wheels & Tires Discussion
Feb 4, 2004 12:34 PM
needforsleep
13
Nov 18, 2003 11:06 AM
