Side to side play in the front wheel...tie rod ends worn?
Old Jun 24, 2007 | 11:50 AM
joe@vwvortex's Avatar
Default Side to side play in the front wheel...tie rod ends worn?
I notice a bit of vibration under soft to moderate braking so I jacked up the car and wiggled the wheel - it moves a bit side to side. I would assume tie rod ends or possibly ball joints - anyone replaced these recently? Cost?
Old Jun 24, 2007 | 12:14 PM
FinnTT's Avatar
tie rod inner joints... they go bad at 60k.
Old Jun 24, 2007 | 01:17 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Side to side..>>
Usually in the tie rod end or arm...Look at the outer end and see if there's any movement of the joint while wiggling...
Up and down would typically show off any ball joint problems..
Old Jun 24, 2007 | 01:28 PM
J. Patterson's Avatar
Default Re: tie rod inner joints... they go bad at 60k-----. Please Elaborate.
I have been suspecting inner tie rod ends as source of my "backing up and turning" clunk. I don't however find any play when jacked up and wiggling tire . I do wonder that as the suspension drops as the car is lifted that that might eliminate play that is there at normal ride height due to the more acute angle of the inner (or even the outer ) tie rod ends while the suspension is in that abnormal position. Did that make sense? :-) Did you have a clunk sound when backing up and turning? I'm doing shocks next month. It would be nice to have the tie rod ends on hand at the same time if I need them. TIA
Old Jun 24, 2007 | 05:03 PM
Default Yeah - a bit tough without a lift - what is an "inner" tie rod? I checked ETKA
and they list the assembly or just the "end" which is what I normally associate with a tie rod problem. Doen't look like there is anything "inner" to me.
Old Jun 24, 2007 | 05:09 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You have to buy the assembly if you want the whole inner and outer..
RemoTT told me he found one for <$50
Autohausaz I think..
Old Jun 24, 2007 | 05:35 PM
Default Hmm - they have em for $40 each side - TRW - I can see the inner assembly in the pic
they have on the site. ETKA illustration just shows the "rod" and no end. I'll check into this. I need an alignment anyway. Thanks Steve. Strut bar looks great - thanks :-)
Old Jun 24, 2007 | 05:55 PM
GorTT's Avatar
Default just for the heck of it >
not possibly the BBK (I know, I know...)? Also, they can develop a shudder if the wheel bearings are going.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 24, 2007 | 07:14 PM
Default Thought about that too - but with the side to side play .....
I figure i'd get that checked first - it's going into Stasis - so i'll have em give it the once over as well.
Old Jun 25, 2007 | 06:07 PM
audispiff's Avatar
Take the car to an experienced mechanic. Probably the inner tie-rod. It tends to wiggle underneath the boot, so it's harder to see, so most go by "feel"....
egustaps
Sep 17, 2008 07:25 PM
Tourette(AFC2.812v)
Oct 1, 2006 02:06 PM
audi2.7audi
Oct 7, 2005 04:19 AM
Illinoid
Apr 5, 2005 06:42 AM
Hokie - STI avant
Jun 10, 2003 11:06 AM
