So I found my leak and I need advice
Old Jun 24, 2007 | 07:52 PM
A_Fbb2001s4's Avatar
Default So I found my leak and I need advice
It turns out that the tube for the dipstick is broken and so I imagine I at least need a new one of those. For now I removed the plastic part of the tube and taped the hole off with duct tape and although the leak is still there it is very very small. My problem now is that I started the car up and drove it around the block just to test things out and it seems to be burning oil now because my exhaust is very visible and smells quite bad which it normally does not.
What should I do and why would it be burning oil now but not before I removed the tube. I was very careful not to get any dirt in the tube while taping it off.
Old Jun 24, 2007 | 08:17 PM
Default Is it possible that this was my leak actually?...
When I pressure tested the car the dipstick tube was the place I could really hear air coming from but could that mean I have a bigger problem?
Old Jun 24, 2007 | 08:28 PM
Default Also, what do I do if some of the orange plastic fell down the tube? Not sure if any did but...
just in case what should I do?
Old Jun 25, 2007 | 03:47 AM
andrew.tt's Avatar
your oil filter will catch it. do an oil and filter change asap.
Old Jun 25, 2007 | 03:58 AM
Rocky-in-Connecticut's Avatar
Default when you change your oil, make sure oil cooler is screwed on...
..if the oil cooler turns while trying to remove the oil filter, oil can leak badly from that seal. Make sure that big nut securing the oil cooler is torqued correctly.
Old Jun 25, 2007 | 04:56 AM
I will do that today then right after I pick up a new tube and install it.
Old Jun 25, 2007 | 04:57 AM
I will check this as well and thanks
mexiaudi
Mar 30, 2011 04:53 AM
May8
11
Oct 31, 2007 08:28 PM
StreetCrawler(Cole)
Jun 13, 2005 11:15 AM
Green96A4
Mar 9, 2004 04:14 AM
gg117
Jun 25, 2001 10:38 AM
