does any one see 102-103 degree water temp after heavy boosting then idling
Old Jun 25, 2007 | 05:15 AM
adminisTerTurbo's Avatar
Default does any one see 102-103 degree water temp after heavy boosting then idling
just making sure it's ok, only happens after driving hard then cutting off it's airflow. brand new 87 degree behr thermostat. wouldn't be sticking would it? i'd imagine the temps would be higher if it were. brand new water pump and new coolant.
fans do come on, but they are pretty quiet. wondering if there is a high speed that's not working.
Old Jun 25, 2007 | 05:25 AM
GorTT's Avatar
sure - not unusual.
Old Jun 25, 2007 | 05:26 AM
LiTTespeed's Avatar
Default don't the fans kick in at 104? IIRC that's fine..... I always felt mine was running hot
as well but after 2 timing belts on 2 different TTs, I think that's fine - especially off hot asphalt where the car doesn't seem to be able to cool as easily. Maybe I'm wrong and if so I'm sure one of the esteemed gurus will point it out.... When did you do a coolant flush last?
Old Jun 25, 2007 | 05:27 AM
mad scientist's Avatar
Junior Member
Default I used to...
after spirited driving, then idling along on a friend's dirt driveway for 1/2 mile or so. Shouldn't be a problem.
Old Jun 25, 2007 | 05:28 AM
Scenic Driver's Avatar
Mine does it from time to time
Old Jun 25, 2007 | 06:16 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Yes, down in Charleston this w/e: ambients were near 100*F.
Heat Soak!
Old Jun 25, 2007 | 06:22 AM
put new coolant in 3 weeks ago...
Old Jun 25, 2007 | 06:41 AM
LiTTespeed's Avatar
i'm sure it's ok - any air trapped in there - aka does it need to "burp"?
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 25, 2007 | 06:43 AM
Default it burped alot so far, i think it's ok too
turbo is just hot!!!!!! i guess. heat soak FTL.
Old Jun 25, 2007 | 08:01 AM
sTTr1ke's Avatar
New Member
Default Re: does any one see 102-103 degree water temp after heavy boosting then idling
I'm pretty sure it's normal... I'm getting the exact same readings after I did my TB and thermostat (DG TB kit) change a few weeks back. After some "spirited" freeway driving, i always tend to run up to about 102 when i finally come to an idle. The fans would always kick in around 101 and everything i've read says it's normal. It also probably doesn't help that it's been like 105-110F for the past 3 weeks (i live in Vegas).
