Thinking of buying the pss9 people who still have em>>>>
Old Jun 25, 2007 | 10:28 PM
DeadLy's Avatar
Junior Member
Default Thinking of buying the pss9 people who still have em>>>>
Do you regret buying this kit? does the rear really "collaspe"?
Any Pro's n Con's?
Thanks
Old Jun 25, 2007 | 11:15 PM
DeadLy's Avatar
Junior Member
Default another question>>>
I know i have to replace my strut bushing, but is there anything else i should replace? bump stop? ball joint? etc....
Old Jun 26, 2007 | 01:40 AM
DerTT's Avatar
Default Loved the PSS9s on my previous 225 CQ ... the rear springs do have >>>
a high rate of collapse. They did so on my friends' R32 as well. He replaced one under warranty and I switched out the rears for H&R Sport springs.
All in all it is a great upgrade- comfortable (the setup is perfectly well damped) and sporty even though it is a bit stiff. The damping control is easy to adjust and can be really stiffened up on the track.
Old Jun 26, 2007 | 01:43 AM
DerTT's Avatar
Default As a pure suspension job, that should be it. Depending upon miles >>>
you may do ball-joints and the sway bar end-links to refresh the front end a bit, but it is not a requirement if they are not leaking grease or making noise.
Old Jun 26, 2007 | 04:20 AM
coasTTal's Avatar
Changed to H&R rear springs also and been very happy since doing.
Old Jun 26, 2007 | 04:25 AM
[KRAFTIG]'s Avatar
Save some cash, buy Koni.
Old Jun 26, 2007 | 06:04 AM
joe@vwvortex's Avatar
Default Stut bush and bearing should do it. Also - i'd suggest looking into DEFCONs as well
which would allow you to replace the bushes in the lower control arms.
Old Jun 26, 2007 | 01:18 PM
DeadLy's Avatar
Junior Member
Default Not about the money; I just like the fact it is so easy to adjust>>>
without any guess work involved. Also I already have defcon's.
And to the guys who are running H&R rear springs on pss9; which springs are you using? Got a link?
Thanks
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 26, 2007 | 02:44 PM
DeadLy's Avatar
Junior Member
so the settings on the pss9 1-9 is 1 or 9 softest?
JPAmerica
Oct 24, 2006 08:17 AM
QS -
Jul 31, 2006 09:35 AM
quattro v1.0
Quattro: Turbo / Ur / Sport
Dec 6, 2004 09:06 AM
s4gonebabygone
Dec 1, 2004 10:07 AM
