So maybe 20 mpg is not average after all!!!
Old Jul 12, 2007 | 03:22 PM
The Chad (VaultPSU)'s Avatar
Default So maybe 20 mpg is not average after all!!!
<center><img src="http://lh3.google.com/chad.lindell/Rpa2XQQT6II/AAAAAAAAACs/ezjv90Bl2nI/IMAGE_025.jpg?imgmax=576"></center><p>Replaced the fuel filter. This is what came out!! And there was plenty more to come out too...
@75,000 it looks like that was the original! Hopefully now I average better than 20mpg!
Old Jul 12, 2007 | 03:27 PM
macdady's Avatar
Exactly where and how hard is it to get to?
Old Jul 12, 2007 | 03:37 PM
Qu!cksilva's Avatar
Junior Member
Default I could get 30 mpg on a highway run as tuned as I was
as long as I stayed outta boost =D (that was and will be the hard part)
Old Jul 12, 2007 | 03:38 PM
Default Right in front of rear right jack point >>>
Remove a few bolts holding the plastic shield over the gas tank, loosen the clamp on the filter, push button on leading edge of each plug on the ends, put down paper towels, put on rubber gloves, pull both ends, wait for small amount of fuel to drizzle out, slide out filter, slide in new, push plugs back on, and put everything back together. Was about a 10 minute job, very easy.
Old Jul 12, 2007 | 03:40 PM
Default Haha yeah right!!!
I stay outta boost long enough for the engine to warm up... Not sure how to keep my foot off the gas after that. Boost is soooooo much fun and with that stage 3 you have, I highly doubt staying out of boost is even possible!
Old Jul 12, 2007 | 03:45 PM
Qu!cksilva's Avatar
Junior Member
Default ...Well if a Corvette or M3 wanted to play...
I had to oblige more often than not ;-)
But if I was behaving...set the cruise control...and just chug along like the rest of the Sheeple...Baaaahhh =)
Old Jul 12, 2007 | 03:48 PM
Audiboy's Avatar
But your mpg will drop now that more fuel will get through. Put the dirt back
Old Jul 12, 2007 | 04:03 PM
OH GOOD POINT! Is there OEM dirt we need to buy to put in?!!
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 12, 2007 | 04:36 PM
BluHeaven's Avatar
Default I had mine replaced at 40k just because if they get clogged it can kill your fuel pump
and not getting enough fuel pressure/fuel is bad enough.
Old Jul 12, 2007 | 04:42 PM
TTinCT's Avatar
Rest In Peace
ewww......it was due!
