turbo problems?
Old Jul 12, 2007 | 07:01 PM
4knfast01's Avatar
New Member
Default turbo problems?
my check engine light is steady on. audi diagnosed it to be the diverter valve. its aftermarket and they blamed it on that. now the problem is when i accelerate hard i get lags in acceleration that never happened before any suggestions?
Old Jul 12, 2007 | 07:10 PM
TT_Nuge's Avatar
Senior Member
Default What DV? What maintenance have you done? Have you verified it's in working order?
If it's a diaphram style the diaphram could be torn. If it's a piston style then it could need cleaned and lubed. OEM DV's are fairly cheap, could throw one on and see if the issue is better, then if so the dealer should be able to look into something else.
Old Jul 12, 2007 | 07:22 PM
DumpTTruck's Avatar
Is it a DV or BOV?
Old Jul 12, 2007 | 09:51 PM
Badd TT Bone's Avatar
Limp mode ? Vag it see if any codes come up
Old Jul 13, 2007 | 04:10 AM
Rocky-in-Connecticut's Avatar
Default step one: return engine to stock form
see if CEL goes awya after clearing codes with Vag Com
Old Jul 13, 2007 | 05:42 AM
kodeTT's Avatar
Elder Member
Default put in the OEM DV...clear the codes and see what happens. less variables helps to diagnose
the problem areas.
Old Jul 13, 2007 | 10:39 AM
4knfast01's Avatar
New Member
Default Re: What DV? What maintenance have you done? Have you verified it's in working order?
im going to put the oem dv back on to see what happens thanks guys.
bradaudi
A4 (B8 Platform) Discussion
Aug 11, 2011 08:05 AM
n2000snake
May 6, 2008 01:42 PM
umbra
May 2, 2003 06:46 PM
LOKE_IT
Florida Discussion
Mar 13, 2003 06:46 AM
