DTC Pull questions - can someone scan this and let me know if there are any biggies?
IConsole has been replaced, 35600 mi total, car is just about perfect cosmetically... need to replace the shifter surround/**** and a plastic panel or two.
Also question on CPO vs non CPO. Dealer will CPO the car for $1K, I am a self-maintainer and can probably fix most anything mechanical. Can't fix ABS or other complex electronics however. Is there anything common that breaks on these that costs close to the cost of the CPO?
Any help appreciated.
Friday, 13 July
2007, 16:48:48VAG-COM Version: Release 504.1-
UDChassis Type: 8N - Audi TTScan: 01 02 03 08
15 17 22 35 37 45 54 55 56 -------------------
--------------Address 01: Engine Controller:
8N0 906 018 BB Component: 1.8L R4/5VT G
0003 Coding: 07710 Shop #: WSC 01236
TRUWT28N331010507 AUZ5Z0B9145161No fault
code found.Readiness: 0000 0000---------------
------------------Address 03: ABS Brakes
Controller: 8N0 907 379 H Component: ESP
ALLRAD MK60 0101 Coding: 0022544 Shop
#: WSC 01236No fault code found.--------------
-------------------Address 08: Auto HVAC
Controller: 8N0 820 043 A Component: TT-
KLIMAVOLLAUTOMAT D03 Coding: 00140 Shop #:
WSC 012361 Fault Found:00604 - Potentiometer
Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus -
Intermittent----------------------------------
Skipping Address 15-Airbags-------------------
--------------Address 17: Instruments
Controller: 8N1 920 980 E Component:
KOMBI+WEGFAHRS. M73 D14 Coding: 07244 Shop
#: WSC 09222 TRUWT28N331010507
AUZ5Z0B9145161No fault code found.------------
---------------------Address 22: AWD
Controller: 02D 900 554 C Component: HALDEX
LSC ECC 00101 Fault Found:00526 - Brake
Light Switch-F 27-10 - Implausible
Signal - Intermittent-------------------------
--------Address 35: Centr. Locks Controller:
8N8 962 267 F Component: Central Lock/Alarm
D09 Coding: 15884 Shop #: WSC 012361 Fault
Found:01374 - Alarm triggered by Terminal 15
35-00 - ------------------------------
----Address 55: Xenon Range Controller: 4B0
907 357 Component: LEUCHTWEITEREGLER D004
Coding: 00010 Shop #: WSC 01236No fault code
found.----------------------------------------
---------------------------------------Address
56: Radio Controller: 4B0 035 186 H
Component: concert II NP2 0050 Coding:
00302 Shop #: WSC 00000No fault code
found.End
