Axle shaft torque specs?
30 mm is different. It depends what you have. This is what bentley says. It kind of jumbled up.
Condition of components on vehicle, as installed Wheel hub being replaced? Procedure during assembly
Drive axle is bonded to wheel hub not replaced Thoroughly clean adhesive residue from splines of drive axle and wheel hub.
Apply locking fluid D 185 400 A2.
Tighten 12-point nut to 265Nm.
Drive axle and wheel hub are greased not replaced Apply grease G 052 142 A2.
Tighten 12-point nut to 190Nm plus an additional 90° 1/4 turn.
Drive axle is bonded to wheel hub replaced If 8N0 407 613 A or B is being installed: Thoroughly clean adhesive residue from splines of drive axle.
If 8N0 407 613 is being installed: Thoroughly clean adhesive residue from splines of drive axle.
Drive axle and wheel hub are greased replaced Install 8N0 407 613 A or B only: Apply solid grease G 052 142 A2.
