about to change the brake pads on my Wilwood...same as OEM? take caliper off and retract
Old Jul 15, 2007 | 06:24 AM
kodeTT's Avatar
Elder Member
Default about to change the brake pads on my Wilwood...same as OEM? take caliper off and retract
the piston?
i have the bridge bolt type...and typically, i can take the bridge bold off to have access to the pads itself...which i put brake quiet on after the fact...but never did a complete brake pad replacement.
question is, do i take the calipers off like i would the OEM calipers and retract the piston (obviously) to put the new pads in? TIA
Old Jul 15, 2007 | 06:34 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Mine just had a retainer pin...>>
Once removed, the pads would just slide out of the assembly. No un-bolting required..YOu can retract the pistons by levering them against the rotor using a large screwdriver.
Dunno if yours are different. These were the styled Dynalites..
<img src="http://images5.fotki.com/v71/photos/7/7305/853674/DSC02340-vi.jpg">
Old Jul 15, 2007 | 06:40 AM
kodeTT's Avatar
Elder Member
Default that easy? not like the OEM piston where you have to rotate the piston to retract...
i can do that very easily. mine slide right in...well, when i put brake quiet on.
didn't think that they would retract that easily back in. mine are superlights. similar, but not the same caliper housing. thx!
Old Jul 15, 2007 | 06:58 AM
GorTT's Avatar
no - just pull the bridgebolt, pull the pads and slide in the new ones - it's a snap.
Old Jul 15, 2007 | 08:00 AM
AxeYrCat's Avatar
Member
As mentioned, most BBKs make it a piece of cake to swap out pads. Quite nice, really. =D
Old Jul 15, 2007 | 10:12 AM
kodeTT's Avatar
Elder Member
Default thx. i DO have to press the pistons back in (retract them back into position), yes?
otherwise, the new fatter pads won't fit.
Old Jul 15, 2007 | 10:19 AM
AxeYrCat's Avatar
Member
Yes. Just don't use anything pointy (that could potentially poke holes in things). Obviously. ;-)
Old Jul 15, 2007 | 11:09 AM
GorTT's Avatar
Default Yes, but they can be pressed w/o too much trouble >
I guess it could be a pain if the pads are really worn; I just 'canted' the pads slightly and used their backing plate to grab the edge of the piston and press them back into the caliper as I worked the pad in.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 15, 2007 | 03:21 PM
kodeTT's Avatar
Elder Member
gotcha. thx.
Old Jul 15, 2007 | 03:22 PM
kodeTT's Avatar
Elder Member
Default sounds like a plan. large flat blade for leverage. OEMs are much harder to retract, so i would
think that all calipers would be similar. this will be much easier.
thx Chris.
Snopyro
Jun 18, 2005 07:44 PM
JBM
Feb 9, 2004 04:14 PM
bsewall
Mar 13, 2003 01:42 AM
audifirst
Oct 23, 2001 04:01 AM
