Help needed: oil smell in cabin during idle
Old Jul 15, 2007 | 05:47 PM
audispiff's Avatar
Default Help needed: oil smell in cabin during idle
I've got an '01 TT225CQ that I just got. Had a 180CQ before and the 225 is definitely worth getting. Anyways, onto my problem:
Slight oil smell coming from the vents when the car is stopped but engine running. When the car is moving, the smell goes away. No smoke anywhere to be seen. There was a small stain by the oil pan mating to the block on the pass. side rear, but I wiped that up and all the stuff around and the smell is still there. When the hood is open, the smell seems to be strongest right around the MAF. The car has a K&N drop-in filter on the stock airbox. I opened that up and found a bit of residue at the bottom of the box and wiped that up. The filter didn't seem overly oiled. The smell still seems to be there. Any other places to check? I can't quite see the rear of the valve cover to see if it's leaking/sweating, but because the smell seems to be very strong near the maf/airbox, I'm thinking it's something to do with the air intake/intercooling system.
Any help would be appreciated. Thanks!
Old Jul 15, 2007 | 06:24 PM
Aarononymous's Avatar
Default Check near the cam-tensioner seal, valve cover, get in there with a light & mirror.
If they are leaking you may want to consider checking the suction jet bum to see if it'as clogged. I has the oil burning smell on the GTI with some seepage from the VC/cam tensioner seal, replacing them fixed it.
Old Jul 15, 2007 | 06:28 PM
audispiff's Avatar
Default Re: Check near the cam-tensioner seal, valve cover, get in there with a light & mirror.
Thanks. I was going to check the cam tensioner seal next. One question: "suction jet bum"??
Old Jul 16, 2007 | 03:47 AM
TTinCT's Avatar
Rest In Peace
could be a leaky PCV too.....mine was a mess....
Old Jul 16, 2007 | 04:22 AM
audispiff's Avatar
Default Re: could be a leaky PCV too.....mine was a mess....
How do I check that?
Old Jul 16, 2007 | 04:51 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Look under your manifold for this...>>
<center><img src="http://images25.fotki.com/v903/photos/7/7305/4077386/IMG_1459-vi.jpg"></center><p>
Old Jul 16, 2007 | 05:14 AM
audispiff's Avatar
Thanks! I'll update later with what I find.
Old Jul 16, 2007 | 09:19 AM
LOL, suction jet PUMP, got bums on the mind again I guess.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 16, 2007 | 12:11 PM
TTinCT's Avatar
Rest In Peace
ya knew that pic would help! ;-)
Old Jul 16, 2007 | 12:16 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ewww.....Kinda like..>>
Not changing your underwear for 6 months!
BTW, Just confirmed everything for the Friday Pick-up...We're a go. See ya Saturday!
<img src="http://images26.fotki.com/v942/photos/7/7305/5092718/Picture222copy-vi.jpg">
