Finished off my passenger side Samco upper IC hose along with TCarbon FMIC and Samco intake hose
Old Jul 15, 2007 | 05:50 PM
bushido's Avatar
Default Finished off my passenger side Samco upper IC hose along with TCarbon FMIC and Samco intake hose
Was up mod'ing late last night. That intake hose is a b!tch to get out.
Shot of the engine bay (hoses, dv relo, Modshack Stg 3)
<img src="http://pictureposter.audiworld.com/2135/enginebay1.jpg">
Modshack stuff
<img src="http://pictureposter.audiworld.com/2135/modshackstg3.jpg">
TCarbon FMIC
<img src="http://pictureposter.audiworld.com/2135/tcarbonfmic.jpg">
Had to trim the grills and the driver's side "alien" mount a little to get the hoses to clear.
Also, did a boost leak test while I was at it. Found a small leak at my dv hose at the entension from the relocation, and another small leak at my boost gauge "T"; fixed both.
Then at about 14-15psi, another leak turned up:
<img src="http://pictureposter.audiworld.com/2135/enginebay2.jpg">
The hose right under that arrow (about 1" wide) is leaking around the clamp. Not sure if the hose is damaged or if it's just a loose clamp; it's one of those one time use clamps. Didn't feel like taking more stuff apart to get at that hose, so I'm getting CPO to cover it. This probably explains why my boost levels drop to around 15 psi so quickly. Hope fixing this does the trick.
Old Jul 15, 2007 | 06:03 PM
MiliTTary's Avatar
How long did the FMIC install take?
Old Jul 15, 2007 | 06:12 PM
TwisTTer's Avatar
Default what kind of parking bulbs are you using? Is that legal where you are?
It has a xenon blueish appearance.
I'd like a clear white instead of the yellow.
How much did it cost you?
Old Jul 15, 2007 | 07:02 PM
bushido's Avatar
I'm using white LEDs from 42DD, but they'r not very bright
Old Jul 15, 2007 | 07:05 PM
bushido's Avatar
Default I would say that the FMIC alone would have taken me 2-3 hours...
First time taking the bumper off for me so others might be able to do it in a shorter time.
Old Jul 16, 2007 | 07:02 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default We found quite a mess under there...>>
When we took Han's car apart a few weeks ago. Replaced the "T", PCV valve, and reclamped...
Since it's on the crankcase side it really doesn't qualify as a "Boost" leak as such unless some of the upstream Check valves are bad. Probably won't have much of an affect on that issue depending on what's busted....
<img src="http://images25.fotki.com/v903/photos/7/7305/4077386/IMG_1459-vi.jpg">
&lt;img src="http://images109.fotki.com/v784/photos/7/7305/225766/pcvboost-vi.jpg".
Old Jul 16, 2007 | 07:13 AM
bushido's Avatar
Default I think mine's leaking at the 2nd clamp to the left of the PCV valve in that pic..
Where does that hose go to? TIA!
Old Jul 16, 2007 | 07:24 AM
adminisTerTurbo's Avatar
Default i had the same problem, the valve was separating
it's a bonded 2 piece valve. it was leaking. then, about 2 inches over was another leak. the hose that attaches to the top of the valve.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 16, 2007 | 07:38 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Pic before dissasembly...>
Ultimately the hose going left attaches to the end of the manifold for a VAC/Boost source.
Several check valves etc. in that rat's nest...
<img src="http://images25.fotki.com/v904/photos/7/7305/4077386/IMG_1458-vi.jpg">
Old Jul 16, 2007 | 07:44 AM
bushido's Avatar
Thanks!
