Coolant suggestions?
Old Jul 16, 2007 | 04:56 AM
bullitz400's Avatar
New Member
Default Coolant suggestions?
Hey guys. Just replaced timing belt, water pump (metal impeller), thermostat, and put new g12 50/50 in. New green top coolant temp sensor as well. Engine still heats up very fast and bar is between middle and H. Thinking it may be head gasket......Thanks
Ryan
Old Jul 16, 2007 | 05:07 AM
Scenic Driver's Avatar
Default ...
Verify the temp using the hvac controls, I think the coolant temp sensor shares a ground with another sensor. It could also be your instrument cluster that is the problem here.
Is there any foam in the oil? Did the old coolant look contaminated? One of these or both would happen with a head gasket leak.
Old Jul 16, 2007 | 06:01 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Did you burp the system?...>
You may have an air bubble...
Old Jul 16, 2007 | 02:07 PM
bullitz400's Avatar
New Member
Default Re: ...
How do I check it from the heater / a/c controls? Oil is fine now. Just bubbles up antifreeze out the coolant and gets hot really fast.
Old Jul 16, 2007 | 07:48 PM
DumpTTruck's Avatar
or substantial white smoke
Old Jul 17, 2007 | 04:13 AM
bullitz400's Avatar
New Member
Default Re: or substantial white smoke
No white smoke or any smoke actually. Just burns a lot of antifreeze and leaks out all over. Bubbles all over in the coolant reservoir
Old Jul 17, 2007 | 05:05 AM
Default ...
<a href="https://forums.audiworld.com/tt/msgs/1645513.phtml">click</a>
Also like Steve said there may be air in the system.
Are there any coolant leaks?
Old Jul 17, 2007 | 07:47 PM
DumpTTruck's Avatar
You'd have white smoke if it was being burnt. Sounds like an overheating problem
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 22, 2007 | 12:31 PM
bullitz400's Avatar
New Member
Default Re: ...
Not leaking any coolant just a little oil here and there. Been driving it for about 100 miles now. Seems to get to about 106 and stay there for a while. I have a tcarbon FMIC on now so the radiator doesnt get as much air. sometimes it goes up to about 120 so i shut it off let it sit. drive it some more then goes down to about 99-100. thinking its letting bubbles out of the system but then the headgsket may be leting more in. I have a feeling i have a big project ahead of me.
dubblrest1985
Audi 100 / A6 (C4 Platform)
Dec 18, 2010 12:28 PM
EkSiPd
Jan 17, 2007 04:33 AM
berlina
Mar 16, 2006 10:06 AM
Nor
Jan 30, 2006 06:31 PM
Style12v
10
Sep 16, 2001 08:00 PM
