Would oil in the charge pipe indicate a bad PCV Valve? Would that cause oil smell in cabin?
Old Jul 18, 2007 | 04:42 AM
audispiff's Avatar
Default Would oil in the charge pipe indicate a bad PCV Valve? Would that cause oil smell in cabin?
Repost from below, but this forum doesn't have a good way of keeping a topic alive for people to see.
I have a burnt oil smell in the car at idle that goes away when the car's moving. I checked the charge pipe on the pass side and there was a small puddle of oil. Would this cause the smell? How do I clean it out easily?
Old Jul 18, 2007 | 05:18 AM
TTinCT's Avatar
Rest In Peace
Default it would not.....>>>
and it is normal for the TT, especially if you have a chipped car.
Oil smell could be coming from the PCV valve, an accidental spill that gets agitated from time to time, or your cam seals. All of which are fixable.
If you notice the smell after not running the AC for a while, that has been around for quite a while, and to the best of my knowledge, there is no fix....but someone else may chime in on that...
On the forum...check the radial box in your preferences for tracking threads....it will keep the thread alive for you....
Old Jul 18, 2007 | 07:28 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You need to get under the car..>>
And pull the lower cover off. You may have a leak off the backside of the Valve cover (or in that area) that's dripping down the hot side of the engine. Probably won't be able to see this from the top.
(and track your threads, so you can see the responses, Options are under "Preferences")
Old Jul 18, 2007 | 08:43 AM
N9909E's Avatar
Junior Member
Default Could be turbo bearing seal?
When under a vacuum condition the oil pressure could relieve into the charge pipe. Under boost the oil stays in the bearing cavity. Also could be a clogged turbo oil return line. Oil consuption could be as much as 1 qt./1000 miles.
Maybe?
Old Jul 18, 2007 | 09:30 AM
audispiff's Avatar
Thanks. I checked before, it was clean as far as I could tell.
Old Jul 18, 2007 | 09:36 AM
audispiff's Avatar
Anyway to check the PCV Valve? Thanks on the thread tracking...
Old Jul 18, 2007 | 09:46 AM
TTinCT's Avatar
Rest In Peace
Default right side of the intake manifold <when facing the car>>>>
look in the area along side the intake runner on the right or just to its left. If it is covered in a gookie oily mess....it is probably the valve gone bad. It is not easy to get too...
Old Jul 18, 2007 | 09:49 AM
audispiff's Avatar
Default Do you have to take the intake manifold off to get to it?
Mine has some oil covering it, but it looks more like "sweat" rather than drips.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 18, 2007 | 10:13 AM
TTinCT's Avatar
Rest In Peace
Default that would be the look....>>>
as it does not drip, it is just blow by on the valve.
We had to take my manifold off to get to mine....
hunterp27
14
Oct 13, 2021 12:16 PM
HIstateS8
Jul 5, 2009 08:14 PM
everest1
Jan 31, 2008 01:49 PM
audispiff
Sep 27, 2007 10:24 AM
Darka
Audi 100 / A6 (C4 Platform)
Mar 10, 2004 06:25 PM
