Got the dealer to cover the boost leak I found under warranty>>
Old Jul 18, 2007 | 06:46 PM
bushido's Avatar
Default Got the dealer to cover the boost leak I found under warranty>>
I posted regarding finding a boost leak at the hoses under the manifold, so I brought my car to the dealer today. Got them to do a smoke test to check for leaks and sure enough, the one I found turned up. Turns out my "suction jet pump" was leaking and they replaced it with a new piece:
<img src="http://pictureposter.audiworld.com/2135/suction_jet_pump.jpg">
The car is now leak-free, but I haven't had a chance to try out how boost is holding; bad traffic all the way home. Might take it for a spin later tonight.
Old Jul 18, 2007 | 06:53 PM
Room4TU's Avatar
How did you suspect that your boost was leaking?
Old Jul 18, 2007 | 07:03 PM
bushido's Avatar
Default I couldn't get the boost machine to hold boost steadily above 15psi>>
Changed both the temp sensor and MAF with no results so I pressure tested the system while doing FMIC and intake hose install and found a few leaks.
- small leak at the boost gauge tap
- small leak at the extension for the DV line from DV relo
- fairly big leak from under the manifold
Fixed the first 2 myself pretty easily since they wouldn't be covered by warranty, and decided to bring it in for the last one. Smoke test at dealership confirmed that it was the only other leak.
johnkk
Jun 28, 2017 04:33 PM
eph94
New England Discussion
Jun 24, 2007 12:22 PM
eph94
Jun 24, 2007 10:35 AM
1 dott 8
Oct 22, 2006 09:44 AM
NOLAN5162
Mar 9, 2004 07:27 PM
