Advice on possible TT purchase
Old Aug 3, 2007 | 11:04 AM
roguenode's Avatar
Junior Member
Default Advice on possible TT purchase
I'm a former 2000 A4 1.8TQMS owner, who is looking at a 2000 Quattro TT Coupe. It has 100k miles, single owner and in great shape, has all major maintenance performed up to this point and has always had synthetic oil.
I've never had a car with this many miles and I'm a bit concerned about costs for 2 yr ownership. Are there any major costs over the next 45k I should keep in mind?
Do you consider a reasonably maintained bone-stock TT Quattro with 100k miles to be a solid daily driver for 2 years? (Daily mileage under 20 in city.)
How well does the TT quattro work in snow? I am hoping to drive this to Breckenridge once or twice a year as well. Any issues with the 1.8t at 10-11k elevations?
Also, opinions on how comfortable the TT is for all-day long-distance drives?
TIA for any advice.
Old Aug 3, 2007 | 11:22 AM
RoberTT-WWCD's Avatar
Default I have a 2K CQ with 111K on the odometer. Things to look for...>>
I just replaced my sway bar down links all around. You will notice knocking and noise when going over any king of uneven serface. Price if DYI $110.
The timing belt should be replaced at the 60K mark. So around 120K that SHOULD be replaced. Parts are around $280 for everything including coolant.
The O2s are close to going bad. I replaced mine at 90K
Check the brakes for wear and if it is a quattro, the haldex fluid and filter is changed every 20K Parts around $65.
To keep the engine in tip top shape, use synthetic oil and change it every 5K.
Parts on the cars are link the A4 that you had. They wear out over time.
go here for link to parts and mods: <a href="http://mysite.verizon.net/vze7srd4/Audi_TT.html">Mods and Parts...</a>
Use the FAQ under my sig for more help.
Old Aug 3, 2007 | 11:23 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Major Maintenance........>
Generally doesn't include the timing belt, which needs to be done before you drive that car even a mile. Figure $1000 or thereabouts immediately. You also need new suspension components so tack on another $1200 there.
They're great in the snow and will be a comfortable distance driver provided you renew the suspension..<ul><li><a href="http://forums.vwvortex.com/zerothread?id=2929038">Here's a good buyers guide....</a></li></ul>
Old Aug 3, 2007 | 11:32 AM
roguenode's Avatar
Junior Member
Default Re: Major Maintenance........> I figured timing belt, but hadn't...
...thought of suspension wear.
I gathered the Haldex setup was good in snow, just checking since the a4 awd setup is different from what I understand.
Thanks!
Old Aug 3, 2007 | 11:41 AM
roguenode's Avatar
Junior Member
Default Re: I have a 2K CQ with 111K on the odometer. Things to look for...>>
I wish I could do the timing belt myself, as 280 trumps 1000 by quite a bit. But, I'm have no real engine work background and limited tools. Sway bar links I could do though. I'll add O2 sensors to my list.
The brakes and Haldex fluid should have been well kept as the owner says he has records of all Audi service points done at dealer. He says he runs synthetic and I hope to get a receipt or invoice showing the last change.
Thank you. I'll keep searching to learn more and will continue to plan on checking the car this weekend.
Old Aug 3, 2007 | 11:45 AM
oc_tt's Avatar
I've taken mine on several road trips. I don't mind it at all, easy to zip in and out of traffic.
Old Aug 3, 2007 | 11:47 AM
Scenic Driver's Avatar
If you have any back issues the seats can be very uncomfortable for long distance driving
Old Aug 3, 2007 | 12:06 PM
Default The shocks on these cars are not very good. Most here have replaced them...>>
with better equipment. I replaced my springs and shocks about 4 years ago and no problems yet.
If you like the ride, just replace the shocks - Bilstein HDs are a good match with the stock springs as well as the new Koni FSD.
If you replace the springs too, you will need to add a rear camber kit to get the camber back into spec. there are two wasy - adjustable tie arms or K-Mac bushings that replace the inner bushings on you existing arms.
You also need to replace the upper stru bushing and bearing. They tend to go out around 60K. ECS has them as a kit for around $50 I believe.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 3, 2007 | 12:17 PM
SparTTan's Avatar
Might be needing a new clutch soon, if it hasn't been replaced already.
Old Aug 3, 2007 | 12:23 PM
Default True. Mine is fine right now. But won't last another year...>>
with the miles I've been putting on.
