?? about coil pack replacement, Push on vs Bolt on
Old Aug 5, 2007 | 11:03 AM
sandyc's Avatar
Default ?? about coil pack replacement, Push on vs Bolt on
My engine type is 1.8L BEA.
I just realized I have the push in style coil packs but I ordered the bolt on (P/N 06B 905 115 E) by mistake.(Duh!!) Do I need to send them back or will these work? Of course, they didn't come with the bolts so can I find these at my local parts store? And what size/type would I need to ask for?
Old Aug 5, 2007 | 01:50 PM
blackfnTTruck's Avatar
I think the holes are there for the bolt in type, not sure what size bolts.
Old Aug 5, 2007 | 02:54 PM
TTington's Avatar
Default I just did my coilpacks I had the bolt type...you need to pull your packs....
that you have now and check and see if there are bolt holes...if you have bolt holes let me know and i will send you the sizes as I have the bolts.
Old Aug 5, 2007 | 04:54 PM
sandyc's Avatar
Default Yes, the bolt holes are there but...
after further investigation I see that the holes for the 2nd coil pack are already being used to hold down the N249 (black bracket). Must be why Audi makes the 2 different styles. Looks like I'm going to have to return them & get the push in after all. ARGH! Thanks anyway.
Old Aug 6, 2007 | 04:08 AM
DasTT's Avatar
Default Correct part number for BEA - 06A 905 115 A -->
Bolt is M6 x 30 allen head. (N 101 174 03), you tie in the vacuum components with the coil pack.
thegoop
Q5/SQ5 MKII Discussion
Aug 19, 2018 11:50 AM
pearlwhitesix
12
Mar 29, 2012 09:31 PM
thecouga
Mar 24, 2007 01:18 AM
moribundman
12v V6 Discussion
Aug 16, 2004 05:26 PM
