anyone local to metro detroit able to help me vag-com my car?
Old Aug 7, 2007 | 02:48 AM
chosos's Avatar
Default anyone local to metro detroit able to help me vag-com my car?
i only have the freeware version and need to figure out why I am only in 3psi / 3hg.
When I drive the car it literally shows +/- 3 on my boost gauge. Before I would drive and show like 20hg vac, and well... now its at 3.
No clue what is going on, and i would say its a leak, but it feels too consistent with the +/- 3 to be a leak.
Old Aug 7, 2007 | 07:44 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Probably a major leak..>
Or kink in your Boost gauge line to start (or a faulty gauge.) No Way Idle (even WITH a leak) would be at -3hg and still run OK. Fix that first. No CEL or rough running?
Old Aug 7, 2007 | 01:14 PM
chosos's Avatar
Default it seems like it runs okay other than my boost seems weak. bad n75?
would a faulty n75 do that?
Old Aug 7, 2007 | 01:49 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Huh? The numbers you quote do not compute...>>
Check out the Boost Gauge install First, then we'll move on to other things..N75's rarely go bad...They're dumb solenoids that take their instructions from the ECU which depends on a whole slew of sensors to work correctly.
Old Aug 7, 2007 | 03:04 PM
chosos's Avatar
checked it - gauge and install are fine. i havent a clue.
Old Aug 10, 2007 | 04:02 AM
chosos's Avatar
fixed that issue - hose off FPR was broken under the mesh covering.
liTTo
Mar 12, 2007 02:08 PM
Monkeyboy
Feb 10, 2007 04:09 PM
HACK THS
Oct 3, 2005 02:34 PM
s4florida
Apr 4, 2005 08:18 PM
Justin517
Apr 13, 2004 12:16 PM
