For an 8.5" wide rim, which is a better width? 245 or 225??
Old Aug 7, 2007 | 12:12 PM
Seneb's Avatar
Old Aug 7, 2007 | 12:15 PM
TTinCT's Avatar
Rest In Peace
Default 225 will give you a slightly stretched look, although there are a >>>
few tires recently that got reviews in European car that have a slightly larger rim guard.
245 is tough in the front depending on the offset of the wheel....personally, i went with 235 on a 19 X 8.5 and this worked perfectly....
Old Aug 7, 2007 | 12:18 PM
Seneb's Avatar
Default Thanks Hans. I'll look for those then. For some reason I went straight to the 245s...
I'm planning on getting the Artics from ER, and they bundle a 225 with both a 7.5" and 8.5" rim, so I figured a little wider would be better for the 8.5" rim.
Old Aug 7, 2007 | 12:39 PM
TwisTTer's Avatar
I have 235 on my 8.5"
Old Aug 7, 2007 | 12:40 PM
BTTI's Avatar
Senior Member
Neither...235
Old Aug 7, 2007 | 12:44 PM
kodeTT's Avatar
Elder Member
Default Toyo T-1R need a wider tread...so a 235 with Toyo looks stretched versus BFG KDW which
looked just right. in fact, the rim guard doesn't even work with the 235 on my 8.5" wide wheels...stacked, the wheels touch each other, not the rim guard. the BF Goodrich KDWs fit better and the rim guard was just right with the 235 width. every tire manufacturer is different, so make sure you check before buying.
Old Aug 7, 2007 | 01:53 PM
furiousgeorge's Avatar
I run 245/40-18 Falkin 512's on a 8.5" Looks like a 255 would protect the rim, the lip now does not
Old Aug 7, 2007 | 02:08 PM
Seneb's Avatar
Default Ordered!!
Flik Artic in gunmetal - 18"
Nexen 3000 (not great, but I do mostly highway driving) 235/40/18
Should be here next week. I'm planning on refinishing my stock rims and will probably use them for the track. Maybe I'll sell them - I have five. =)
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 7, 2007 | 02:47 PM
aTTicism's Avatar
Dr.Duct_Mossburg
10
Jun 1, 2007 08:22 AM
downunder
13
Feb 26, 2006 02:46 PM
BSCA4
Apr 2, 2004 03:08 PM
bugzy SoCalEuro.com
Wheels & Tires Discussion
Feb 27, 2003 03:07 PM
drhaller
Jan 20, 2001 07:28 PM
