Well it had to happen, nice little crack in my oil pan from big rock...
Jack it up, sure enough right where the oil drain fitting is the pan looks like it got a little dinged up. I have had minor scuffs here and there right by that location from speed bumps etc. This was was a bit larger and deformed it a touch on the bottom where I couldn't get a socket around the plug. Nothing crazy, but enough. Noticed it looks like the area around the drain plug is not part of the actual oil pan- it is still metal, but I notice a seam about a cm around the whole plug. It looks like I have a small leak right at the bottom of that seam. I wipe it away and oil slowly starts to fill in the seam again.
Not even going to bother with getting it fixed, just going to get a new oil pan. I know a few others have done this, how is that job?
I noticed that ECS has a steel and aluminum pan- steel is said to be harder. Also found them on ebay around $100, but I am going to stick with someone that knows. Anyone with details on the install would be appreciated.
Wonder if this would have happened if I had my under engine plastic shield on
Just hoping the install not too much of a PITA to do on jack stands. God I need a lift lol
