maintenance advice needed
Old Sep 11, 2007 | 01:51 PM
mike_balt's Avatar
New Member
Default maintenance advice needed
Wife's TT (2001 quattro coupe) has not been to dealer since 40K miles. Currently has 75K on it. What maint do I need to do?
Seems like I'm overdue for a timing belt per the new standards. Do I need waterpump and any other items at same time? What should that cost.
Anything else?
Thanks for your help. I'm pretty out of touch on the TT, so you guys who live and breath them should be a great help to me.
Old Sep 11, 2007 | 02:07 PM
whodkne's Avatar
Member
Default Haldex, Timing Belt, Tensioners, Water Pump, Oil Change, Spark Plugs
Air Filter
Old Sep 11, 2007 | 02:11 PM
msauve's Avatar
brake fluid
Old Sep 11, 2007 | 02:21 PM
JohnLZ7W's Avatar
blinker fluid
Old Sep 11, 2007 | 02:57 PM
gomezTT's Avatar
Default Don't wait...
A timing belt serivce is urgent in your case...the belt, tensioner, and water pump are always done simultaneously. If any of these fail, you have a 2-4 thousand dollar repair to face. Most reported failures have happened in the 55 to 90 thousand mile range. I just had mine done last month for 1100 dollars at Audi dealer...independents charge about 200 to 300 less.
Old Sep 11, 2007 | 03:14 PM
SparTTan's Avatar
Default No maintenance at all in the past 35K miles? Start by checking tire pressure.
Oil and filter change next, timing belt very soon after. Brake fluid should be replaced every 2 years, regardless of miles.
Spark plugs should be done every 40K miles, so that is coming up.
Old Sep 11, 2007 | 05:16 PM
DumpTTruck's Avatar
Can I say wow? The below lists are good. Don't put off the TB very long!
Old Sep 12, 2007 | 05:36 AM
gregt's Avatar
Junior Member
How about tires? Mine definitely don't last 35k ...
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 12, 2007 | 06:57 AM
mike_balt's Avatar
New Member
Default Re: How about tires? Mine definitely don't last 35k ...
OK, first thanks to everyone for the responses. Looks like timing belt, tensioner and waterpump are due. plugs shortly there after (last done at 40K).
To answer some of the other questions: I may have mislead in my post. It's not that we have not been maintaining (brakes, oil changes, etc.) have all been done. I've just been wondering about the items that don't make themselves known until total failure - like the timing belt. So thanks. And to answer the tire question, we switched to all season (Pzero Nero) so we do get some pretty long life from them (although I think the conti extreme contact all seasons were a better all around tire).
Associate Lurker
Sep 7, 2008 12:44 PM
p3u
Sep 4, 2005 04:30 AM
abdu14
12v V6 Discussion
10
Apr 29, 2004 01:36 AM
CK:1.8T+Rabbitâ„¢
Apr 2, 2004 12:37 PM
sparklinggrapes
Nov 1, 2003 10:41 AM
