boost/vacuum leak found, now what?
Old Sep 12, 2007 | 09:50 AM
quaTTro411's Avatar
Default boost/vacuum leak found, now what?
this hose looks like its gonna be a pain in the **** to replace, does anyone know the size of this hose and if its in the universal starter kit from hose techniques?
<img src="http://images29.fotki.com/v1008/free/b1e46/9/999945/4048692/091207_1221-vi.jpg?1189618810">
<img src="http://images27.fotki.com/v996/free/b1e46/9/999945/4048692/091207_1222-vi.jpg?1189618830">
the leak seems to be coming from the end where it looks like it tees into another hose(would be on the right side of picture from this view)
Old Sep 12, 2007 | 09:56 AM
nikhil's Avatar
Default from what remember, it's really not that tough to replace
once you have that front bracket off (in front of the IM).
&lt;edit&gt; if you're talking about one of the small vacuum lines&lt;/edit&gt; it might be 6mm hose, but don't quote me on that...
Old Sep 12, 2007 | 09:57 AM
adminisTerTurbo's Avatar
Default very common problem, access is limited
some have replaced it with the mani still on. but the clamps will be really difficult to deal with. there is a part number floating around here somewhere.
Old Sep 12, 2007 | 10:03 AM
JohnLZ7W's Avatar
Default Hard to see what's going on there, where does it attach to?
When I did all of the small diameter vacuum lines on my car I used zipties instead of hose clamps for most of the connections on the bottom of the intake manifold.
Old Sep 12, 2007 | 10:12 AM
quaTTro411's Avatar
not sure how to describe, if anyone has an atc engine diagram i could point it out
Old Sep 12, 2007 | 11:22 AM
Default it's probably 06A-133-783-AT
this is a great post<ul><li><a href="https://forums.audiworld.com/tt/msgs/1668313.phtml">PCV hosing...</a></li></ul>
Old Sep 12, 2007 | 11:36 AM
JohnLZ7W's Avatar
That's for an AMU engine tho, not sure if it's the same for ATC.
Old Sep 12, 2007 | 12:23 PM
ah, yarrrr...
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 12, 2007 | 07:24 PM
quaTTro411's Avatar
some of the hoses look similar, but my motor is a 180 quattro
Old Sep 12, 2007 | 07:26 PM
quaTTro411's Avatar
looks like the one coming off the bottom of the t fitting in the top right of the pic
aprA4STAGE3
Jul 18, 2007 08:34 PM
beejohn
Jan 24, 2005 03:16 AM
Imola4
10
Nov 9, 2004 07:18 PM
/APOOOORGUY - OOOOA4
Mar 15, 2004 06:30 PM
Matt E.
Mar 8, 2004 11:17 AM
