Trunk Rattle. Latch tightening or Rubber stops?
Old Sep 12, 2007 | 01:19 PM
alberttien's Avatar
Default Trunk Rattle. Latch tightening or Rubber stops?
Hi I searched the FAQ and found out that the most common sources of noise are latch tightening and the rubber stops. I recently noticed that the trunk was actually lifting about a 1/4 of an inch over some slight bumps in NYC. It was enough so that I could see light through the bottom half of the trunk and the hatch. I'm assuming that i need to tighten the latch. How would I go about doing this? I can't seem to find instructions in the Search.
Thanks
Old Sep 12, 2007 | 01:22 PM
300ShooTTer's Avatar
New Member
Default Re: Trunk Rattle. Latch tightening or Rubber stops?
I had that happen to me last month. I just tightened the latch and it hasn't happened since.
I prolly didn't do it the "correct" way, but I just went at it with a couple flathead screwdrivers to pry the liner out and then used an allen wrench to tighen it. Pretty simple.
Old Sep 12, 2007 | 01:36 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Pop the plastic cover off of the latch..>>
On the hatch. With a torx wrench, loosen the 2 bolts and move the latch assembly up a bit. There are reference lines there to help you with the adjustment. Adjust, try, adjust, try til you get it right..
Old Sep 12, 2007 | 02:07 PM
New Member
Default Re: Pop the plastic cover off of the latch..>>
This works too, lol.
Old Sep 12, 2007 | 02:36 PM
Drollomite Man's Avatar
Default You can also adjust the rubber stops
Insert an Allen head wrench (sorry, forgot what size) up into the center of the stop. Hold the stop with one hand and loosen with the other, as you don't want to lose your reference/starting point. Once the stop is loose, pull out several notches (it's indexed) and retighten.
Old Sep 13, 2007 | 05:45 AM
alberttien's Avatar
Thanks for the quick reply TTschwing!
jetsfan101
12
Nov 15, 2013 12:00 PM
awdinut
14
Jan 26, 2012 11:38 AM
gt fan
Nov 23, 2007 09:25 AM
psuaudi
Apr 9, 2006 01:58 PM
DiviniTTy
Jul 24, 2005 04:46 PM
